One of the exhaust manifold studs is snapped at the head, about 1-2mm is sticking out... any input on what some have done on the exorcism of extractions?
					Broken manifold stud suggestions..
	Tags: None
one suggestion is to use a dremel and cut a flat slot in it for a flat screwdriver to turn it out. That will be tough though. Another thing you could do is get a cheap hex nut that fits it, screw it on, and tack it on with a tig welder, then remove it that way. its going to be tough with only 1 or 2 mm sticking out.
