Will e30 exhaust work ok?
  • OOMPH!
    • 3487
    http://www.turnermotorsport.com/html...DUCT_ID=782406
    Will this Supersprint 325i exhaust work with my S50 set up? Looking for something nice and queit.
  • aeryk7
    • Oct 2005
    • 616
    Piping looks to small in the pic but im not totally sure on this.
    253rwhp
    My Vids(OLD)
    http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
    http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
    • OOMPH!
      • 3487
      no one?
      • T.Dot E30
        • Mar 2004
        • 536
        Do you have a stock cat/mid section?
        If so it will, if you had a custom system put in with the s50, then maybe not unless they used the stock flanges and everything is how it was stock.
        • OOMPH!
          • 3487
          I currently dont have a cat at all, just a resonator box. Maybe it will work if those pipes on the Supersprint muffer are cut off and new ones welded on. I'm trying to get the quietest muffler on my car.
          • C ///M
            • 1040
            Hey, congrats on finishing the clean install.
            As far as your exhaust goes, if you have custom from the manifolds back, your best bet is to pick up a quiet muffler and do custom piping.
            What diameter pipe is your mid-pipe? I happen to have 2 M-coupe mufflers with 3k miles on them. Each muffler has a 3in inlet with the stock dual staggered M3 outlet tips and since the mufflers are much smaller than the standard e36 m3 unit, hanging it properly should be easy and then you need custom piping. I've been holding onto them incase I ever wanted them, but I doubt I'll ever get rid of my E36 M3 Stromung muffler. One of them should mount perfectly on the e30.
            332iS R.I.P.
