ICV bracket part number?
  • MatRacer
    • 562
    I'm presently finishing my to do list to finish my S50 swap. On the engine I got, the ICV was just hanging by the hose = BAD
    Will buy part #11-72-7-545-323 (Item #7)
    My question is on which bracket does this rubber support hang to? Can't find it on Realoem...
    Thanks!
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • MatRacer
    • 562
    anybody that kept the OEM setup could take a look?
    E30 now S52
    325xiT (Sold)
    • FredK
      • 14762
      #7 fits into the stock engine wiring harness metal bracket that sits below the intake manifold. I couldn't find a part number on realoem for this bracket either. It provides a raceway for the engine wiring harness underneath the manifold.
      • Bmwdayz
        • Apr 2011
        • 610
        The top bracket in the photo you can see the rubber piece that holds the ICV. Assuming your engine has that bracket still attached to it. Hope this helps out
        • MatRacer
          • 562
          Wow Thanks!
          With that info, I found the part number (item 5): 12521724264
          unfortunately, I don't have this part. All the wiring harness and stuff was just hanging there... clean job:???:
          I will try to source a used one... If not, pelicanparts sells one for 33$, not that bad!
          E30 now S52
          325xiT (Sold)
