Throttle body port identification
  • MatRacer
    • 562
    On a S50 throttle body, there is two ports for the coolant on the underside. There is an addtitionnal port. Is it for the ASC? What is it used for? Can I just plug it?
    Random pic from google
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • berlow94
    • Jan 2013
    • 1063
    Evap
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
    • MatRacer
      • 562
      evap = line from fuel evap canister?
      E30 now S52
      325xiT (Sold)
      • berlow94
        • Jan 2013
        • 1063
        Bingo! Throttle body, tube, evap valve, tube, evap canister.
        • MatRacer
          • 562
          I think I let go the evap valve valve when I sold my M20. the valve part #13-90-1-711-395 cost 182.25$ on Pelicanparts!!
          Do I really need this valve?!? Looking at the e36 setup and it doesn't seem to have any valve...
          EDIT: FOUND THE VALVE ON THE E36 SETUP
          E30 now S52
          325xiT (Sold)
          • berlow94
            • Jan 2013
            • 1063
            Obd1 e36 has it. OBD 2 e36's do it a little differently. If you want to just delete you evap system, plug the port on the throttle body, then go get a small air filter and clamp it to the end of the hose coming out of the gas tank. (The one that would normally go to your charcoal canister)
            • ParsedOut
              • Sep 2005
              • 1437
              This is what I do, but you'll probably fail an emissions check. I'm sure you can find one of those valves at the junk yard for pennies.
              • berlow94
                • Jan 2013
                • 1063
                Agreed. This is on my track car #1, and i live in NH #2. They have 0 F**k's to give about emissions on E30's. ;)
                • MatRacer
                  • 562
                  Does both the e30 and e36 purge valve fit?
                  E30 now S52
                  325xiT (Sold)
                  • berlow94
                    • Jan 2013
                    • 1063
                    Good question. I don't see why not...
