s14 cluster and tach w/ s52
  • X2theZ3
    • Mar 2004
    • 932
    Originally posted by Ryan Stewart
    I, myself, am curious about the dakota digital adapter because of some people thinking that the tach might still be a little off. Im not sure why since all they need to do is read the # of pulses on one given cylinder or on a CPS but whatever. Mine idles at 600 and says it stops at 7000. I guess the redline is supposed to be 7200 but, in all honesty, I am not looking at the tach when i have bounced it off the limiter.
    Yours should be fairly accurate b/c you didn't use a s14 cluster.
    325Project is right about the s14 cluster with the m20 6 cylinder coding plug.
    "So you need a 6 cyl coding plug, but problem is, bmw never made a 6 cyl coding plug for a 8k tach. If you put the 7k 6 cyl coding plug (325i) in it, at redline, which is 8k, the engine will really be at ~7k. You can switch the gauge face back to a 7k tach (thats no fun though) and it will be spot on."
    It's the problem i have with my car: redlines at 8k but really at 7k. Like mentioned, I wonder if that m5 coding plug will work...hmmm...
    • grapedrink
      • 1514
      Can you buy the plugs at the dealer?
      Originally posted by DaveCN
      Welcome.
      Your car is a piece of shit.
      Most of them here are, too.
      • equate975
        • Jun 2004
        • 3382
        Yes I have done it
        All you need is a 325i(is) coding plug. Just pop the 4 cyl one out and press the 6 cyl one in.
        You "can" use the 325e's coding plug, but it will be off a bit.
        Rollin' with a Geistkuchen
        • equate975
          • Jun 2004
          • 3382
          Yes they are $40 IIRC
          • alexbaby88
            • 219
            I have a E30M3 cluster with M50 and it seems that the speedo readings are also inaccurate, along with the tach's.
            • Brew
              • 3060
              The speedometer gets its signal from the sensor in the diff- the engine swap has no effect on it.
              '91 318is
              • Jason89i
                • Sep 2004
                • 875
                yep, same with every e30 i have owned.....all 9 of them. the speedo is always "optimistic" with its reading.
                with the obc timer, i can figure out the exact speed. cliff notes........set cruse, time (in seconds) how long it takes to drive 2 miles (using the mile markers.) divide 7200 by time.....thats your speed.
                speedo says 80, im actually going 77.0 with 225/40/17's.
                speedo says 80, im actually going 76.5 with stock tire diameter.
                cheers, jason
