M20 Single Mass Flywheel
  • Mike B.
    • Jan 2006
    • 987
    Can the M20 single mass flywheel be machined (and lightened) to work with the M50 and E36 transmission? I guess I'm just being cheap as I don't want to drop big bucks on a new lightweight flywheel.
  • Jason89i
    • Sep 2004
    • 875
    mike -
    i did the m50, lightened flywheel and e30 trans.....but i ran into some difficulties. never did the "i" flywheel with the e36 trans though. if you get a chance, measure the thickness of your proposed clutch assembly......(the distance from the crank mating surface to pressure plate teeth.) I have a few m3 flywheels/clutchs sitting around and can verify that the overall thicknesses of the assemblies are the same. cheers, jason
    • raimo
      • Nov 2005
      • 36
      will the 325i flywheel work with getrag 260 and m50 or not ?
      some guys say it works, some say it doesnt. im in the opinion that i have to use the dual mass flywheel instead.
      • 325Projectz
        • Jan 2005
        • 1956
        It will work. If you go with a m20 flywheel, then you just need to use m20 starter, clutch, trans, and driveshaft.
        And you need to shave either the flywheel or the oil pan.
        91 m3
        • erik325i
          • Jan 2005
          • 3567
          Yes, the m20 flywheel will work.
          We just finished an m50 swap at work and we used:
          m50tu with e36 tranny, and machined down m20 flywheel. Works great.
          -Erik
          • Mike B.
            • Jan 2006
            • 987
            Erik,
            A few more questions...
            Did you use the M20 starter? How much material did you remove from the flywheel? What type of clutch are you running?
            • DanThe
              • Mar 2006
              • 98
              I used M20 flywheel/clutch and starter with my M50 engine/E36 325 trans. An M20 325 propshaft fits perfect.
              6mm is all that needs to be removed from the back of the flywheel as it will contact the bolts on the back of the block, see here \/ before and after.
