So I got my swap running but I've run into a few problems.
1. The temp gauge doesn't work. I start up the car and it goes up to the first line indicating it's working and waiting for the engine to warm up, but no matter how long i run it (not too long because I don't want to overheat it by accident)it just doesn't budge. It has the brown temp sensor on it with the blue one for the ECU. I'm wondering if because my car is a 318 does it need an m42 temp sensor?
2. The tach isn't working properly. It'll show presumably the right numbers when it's idling, but as soon as you go to rev it, the needle just shoots up and goes way past the 7k mark. It's not in sync with the engine at all it seems like.
3. It doesn't idle all too well. It'll be idling and just go up and down in revs. It'll seem like it wants to cut out then the revs just magically go back up. Also sounds like it has a slight misfire when the revs go down? But I could be mistaken.
Thanks for your help!
