M50TU + zf trans clutch won't disengage
  • AlpineCoupe
    • Jan 2013
    • 70
    As the title says I have a M50tu with a zf trans from a 95 m3. I'm using the s50 clutch with the e30 clutch master and m3 slave cylinder. Got the car running pushed the clutch ground the gears. Bled the clutch both with a power bleeder and with the slave out of the car and this time tried starting the car in gear with the clutch pushed and it rolled forward a bit. Clearly can't get the clutch to disengage.
    So I'm at a loss, pulled the slave and tried to manually push the clutch with a piece of bar stock and couldn't get anything to budge. Anyone have any idea what is going on? Thanks in advance.
  • berlow94
    • Jan 2013
    • 1063
    Don't think you would be able to manually push the clutch like that. Sounds like too short of a slave cylinder rod or a not fully bled system to me.
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
    • AlpineCoupe
      • Jan 2013
      • 70
      I did use a 24" pry bar on the bar stock so I was able to apply quite a bit of force. I had read something about the slave from a 325 working but I figured since I was using m3 trans and trans the m3 slave would work. Maybe the master doesn't move enough fluid for the m3 slave?
      • dude8383
        • Jan 2005
        • 10387
        Did you try the two man method for bleeding it? Maybe there's still area somewhere the system?
        • AlpineCoupe
          • Jan 2013
          • 70
          I didn't try the 2 man because I figured bleeding the slave while it's off the trans is essentially the same thing, I'll put it on the list of things to try, thanks!
          • dude8383
            • Jan 2005
            • 10387
            are you sure the slave itself hasn't failed?
            • AlpineCoupe
              • Jan 2013
              • 70
              Brand new febi slave, replaced an AutoZone part figured it would be more stout.
              • AlpineCoupe
                • Jan 2013
                • 70
                A bit embarrassed to ask this but if the throwout bearing was installed on the fork incorrectly would we be experiencing the issues I've described?
                • DesertBMW
                  • Aug 2011
                  • 1042
                  system is not bled properly.
                  • RobertK
                    Kicked cancer's ASS.
                    • Jun 2005
                    • 5864
                    Did you happen to replace the pivot pin? Or at the very least inspect the one that came with the transmission?
                    Had this problem before.. pivot pin was completely smashed down so the throw out arm was too far inward so the TO bearing wasn't getting enough throw.
                    If the clutch slave was not able to move at all when bolted to the trans then your clutch pedal would be hard as a rock.
                    I've also seen this happen with the clutch disc is installed facing the wrong direction but usually on aftermarket performance setups.
                    • AlpineCoupe
                      • Jan 2013
                      • 70
                      Had a chance to look at the pivot and it was pretty well smashed in. Ordered the stainless steel pivot from rogue engineering, hopefully that will help get to the bottom of our issue.
                      • RobertK
                        • Jun 2005
                        • 5864
                        Stainless won't squish but there is a reason it was made of plastic / delrin. High pressure and friction of two metals pivoting against each other will eventually wear a hole. This is why the other aftermarket metal ones are made of brass. Stainless is harder than the steel that the throw out plate is made of. Over time the stainless pin will drill through it.
                        Not a big deal if you will have the trans out for service every few years but a bad long term solution.
                        • AlpineCoupe
                          • Jan 2013
                          • 70
                          Good call with the metal differences, this is a track only car so service intervals will be pretty tight. And I think it would probably take a ton of miles before the pivot actually wore through the fork. But a good thing to keep in mind.
                          Kind of surprised BMW used a stainless pivot on the 8 series, maybe the fork was made to be a bit reinforced where the pivot hits on that model.
                          • RobertK
                            • Jun 2005
                            • 5864
                            All depends on the quality of the two metals but like you said it will see periodic service intervals so I wouldn't sweat it. If you still have issues with the pivot point you can also use some thick washers to space it out 5-10mm if even to just help adjust pedal feel.
                            • AlpineCoupe
                              • Jan 2013
                              • 70
                              Just wanted to post that the new pivot from Rogue seemed to do the trick. Car now drives under it's own power!
                              Clutch engagement is right off the floor (using no clutch stop) but it does work. Thanks for all of the replies.
