50 swap, Check panel no working
  • vaughnbannister
    • Aug 2012
    • 206
    As the title says, i have a s50 swapped e30 and everything works fine. The problem is my check panel isn't working and the light on the cluster is not working (blinking) either. It should have the oil light on because of the swap and also the washer fluid light because i have deleted that. I have searched but i have found nothing.
    Am i forgetting to wire something up?
    Any help is appreciated, Thanks.
    - S50 Swapped E30 1/1 Mineral White -
    @vaughnbannister on IG
  • vaughnbannister
    • Aug 2012
    • 206
    Bump. Still haven't figured this out.
    The check panel it's self works because the seat belt light still comes on when I turn the key.
    • sweet3
      • Oct 2012
      • 753
      Sounds like your harness wiring might be the problem. Did you buy a harness adapter or did you re-wire the harness yourself?
      PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
      • vaughnbannister
        • Aug 2012
        • 206
        I am using the AKG wiring harness adapter. Everything is working perfectly fine. But this haha.
        • sweet3
          • Oct 2012
          • 753
          hmm, then that probably isnt the issue. lol Have you double checked all your grounds? Maybe a fuse?
          • vaughnbannister
            • Aug 2012
            • 206
            all my fuses are good and i dont see what ground it would be for the check panel... it wouldnt be in the engine bay, so the only other option would be under the clove box? is there a ground that comes from the C104?
