Unusual Question to Help with my Supercharger Build
  • MaxBell
    • 1391
    Hey guys;
    I need someone to get out their ruler and measure their engine.
    I don't have access to my M50 right now, could one of you really cool and good looking people take these measurements for me?
    Someone has to have an M50 block sitting around. :D
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • frankie591
    • Feb 2012
    • 545
    I should be able to do this tonight. I'll need to give you a measurement to the big pulley only, as I don't have an ac pulley on mine.
    • MaxBell
      • 1391
      That's fine. It will give me an idea of house much I have to shorten the housing to get it to fit. (without hitting the motor mount arm)
      • frankie591
        • Feb 2012
        • 545
        My block may be different than yours, the holes on mine didn't make a perfect square like the one on your diagram.
        B=120mm for the front holes which are in line vertically
        B=103mm for the rear holes which are in line vertically
        A= 70mm for both sets (bottom 2 holes are in line horizontally, top 2 holes the front hole is higher up than the back hole)
        Distance from front holes to front of crank pulley=~110mm (hard to measure that one)
        Distance from front holes to edge of block casting =10mm
        • MaxBell
          • 1391
          Awesome. Yours is an M50B25? What year?
          Which holes you got?
          • frankie591
            • Feb 2012
            • 545
            Mines an ~96 m52b28, but should be the same. I have all those holes, gave you measurements for B,C,E & F
            • MaxBell
              • 1391
