S50- removed powersteering pump. Anyone know proper belt length?
  • m3j0n
    • Feb 2006
    • 395
    Just wondering if anyone has already removed the power steering pump and knows the new belt length off hand before I go experiment with belts. Thanks!!
    -Jon
  • ArtClassShank
    • Jul 2013
    • 143
    6PK1400 551K6 K060551
    Post 38 is what I based my purchase off, belt worked fine and fitted as indicated. Only thing you have to check is if you have an idler pulley, might change the routing of the belt.
    1989 Carbon Black 328is
    • Nick_S
      • Apr 2011
      • 3658
      I used an oe Mini Cooper S belt. I forget the part number so I guess this probably doesn't help much.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • MyE30
        • Sep 2013
        • 326
        x2. in that thread, post 58 shows a good way to route your belt if you decide to keep your idler pulley. I was able to keep my idler pulley using the 6pk1400 belt.
