Or your engine will sound like this:
It turns out I inadvertently installed the e34 M50 oil baffle that came with my e34 oil pan on my s52 engine. The s52 oil baffle has openings in specific locations to allow the bottom of the crank to have enough clearance not to hit the baffle. The e34 oil baffle does not have these openings and two bolts on the bottom of my crank were hitting the oil baffle, see pictures below.
I was stumped as to what was making the noise so I ended up pulling the engine and removing the oil pan and baffle to see if the crank was damaged and lo and behold the baffle had fresh marks on it. I was surprised the oil baffle was the issue but relieved that it could have been worse!
I hope this helps someone avoid installing the incorrect oil baffle during a swap. Install the oil baffle that came with your engine, not the oil pan!
e34 m50 oil baffle with marks showing where the crank bolts were hitting:
Closer view
Crank bolt heads (inverted torx) worn down slightly from contacting m50 baffle
Correct S52 oil baffle installed, openings for bolts now in place!
Closer view
