Early Model swap VSS Signal
  • pandaboo911
    • 2070
    OBD1 swapped s52 in an '84 318i. Need to provide 413 DME with VSS signal.
    Have a few questions:
    Is the VSS signal that goes to the ECU a direct signal from the diff sensor?
    I am not running a stock e30 speedo, so I can only use the raw output from diff speed sensor.
    My speedo is going haywire when I rev the engine.Is this interference? My speedo is hooked up to the stock sensor signal and ground wires, are these shielded?
    Thx
  • DesertBMW
    • Aug 2011
    • 1029
    it must be processed speed signal from the e30 instrument panel. Won't work directly.
    • pandaboo911
      • 2070
      Can anyone confirm this? I've heard from another source that obd1 uses an unmodified signal from the speed sensor
      • DTFE30
        • Feb 2011
        • 471
        I got mine form the OBC harness. S50 would cut out at 6200 rpm until I provided vehicle speed to DME.
        • jeejee
          • Apr 2014
          • 1
          Hello,
          If you are unable to get the needed signal to the engine DME,
          i might have the solution, I ran into simular problems when installing an e34 m5 engine in a non bmw body, the engine missed 40 wheel horsepower due to a missing speed signal , I have done a lot a research and had a couple speed signal duplicators made.
          My latest m70 conversion didnt work properly without the signal either...
          if you are interested send me an email (oldtimerfan at hot mail) and I can send you some pictures and info..
          I'm not a company or trying to make money, just trying to get some money back for having several made and in the process helping some enthusiasts :-)
          Jeejee
          • pandaboo911
            • 2070
            Thx for the reply JeeJee, I sent you an email.
