I shoulda kept up with the money better as it was a budget build. Truth be known if I included the price off all the parts I didnt pay for the final tally would probably be about 1000 total. Out of pocket expense ended up being around 700. Now this includes everything including the setup to run the 3.5" maf and headers and basically extra shit. If I would have skipped all the extra and just got the car running as it was from the junkyard the out of pocket expense would have easily been below 500. In fact I could have made this motor run in my e30 for probably around 300-400. I mean ignore the go fast parts, ignore the maintenance items that could have not been changed (tensioners, water pump, etc were all fine), ignore the cams, ignore the euro fan and just run stock aux fan, and the cost quickly go down.
Also I should add that while collect junkyard parts for this car I struck gold numerous times and actually made a shit ton of money. So lets break that down too.
Miata Hardtop - paid 60 - sold 650
e39 m5 - motor went to my friend brian, I bought the diff, driveshaft, some trim, and brakes for around 150. Sold diff for 800, brakes for 400, and trim for 80. I have some other misc I still have to sell off of it too. Oh I forgot i sold the abs unit off of it (paid 72, sold 150).
A bunch of other small stuff. Probably no joke total of around 300-400 in small items.
And I have a buyer for my m20 package at 500 bucks.
Anyway here is a breakdown.
Out of pocket expenses. (PAP = Pull a part)
M52B28 from PAP with accessories – 182$
Flywheel machined at Lee Machine down to 15lbs – 40$
AFM from PAP – 20$
ECU from PAP – 30$
Euro diesel clutch fan – 65$
24lb injectors – 60$
Power distro block – 15$
Harness from PAP – 16$
Shift carrier broke so had to have it welded – 25$
Delrin shift carrier bushings – 30$
Bearings for UUC short shifter – 10$
IACV PAP – 15$
SS replica headers – 104$
Air dryer catch can setup – 12 $
3.5” maf – 26$
3.5” maf silicone boot DIY – 20$
Custom A/C lines - 75$
None out of pocket expenses (These were things I got trading labor and/or parts or that already had in spare parts inventory)
S50b30 cams
VC gasket set
E34 oil pan
Oil pan gasket
OBD1 Knock sensors
M50 intake mani and tb
Intake mani gaskets
OBD1 Cam Sensor
CPS
Throttle and cruise cable
Various seals (rear main, shift selector, vanos and prob more im forgetting)
Motul 8100 5w-40 and mann filter
E30 318 harness cover
New Parallel flow condenser (broke mine getting it out)
UUC short shifter (I believe it is a gen 1. Uses ball bearing rather than bushings)
IACV hoses
New 540 fan clutch
e34 cylinder motor mounts
Water pump, Thermostat, New Hoses
All new belts and idlers/tensioners
Tune for 3.5” maf
Red46 skidplate for 24v swap
I reused the existing G260. It had a really great condition Luk clutch and pressure plate in it so I reused those and just deglazed the PP with a prep disc.
Reused stock exhaust fitted to the new header.
AFM from PAP – 20$
ECU from PAP – 30$
IACV PAP – 15$
3.5” maf – 26$
S50b30 cams
VC gasket set
E34 oil pan
Oil pan gasket
OBD1 Knock sensors
Intake mani gaskets
OBD1 Cam Sensor
CPS
IACV hoses
New 540 fan clutch
Tune for 3.5” maf
