very intermittent check engine light
  • Kevinl
    • Oct 2012
    • 897
    today and like 6 months ago the check engine light is on for a little bit while the car was warming up.
    I did a stomp test and got a code 1223 for coolant temperature sensor
    I found a receipt where the previous owner had the sensor replaced like 4 years ago
    Does someone have the spec on what the resistance values are supposed to be on it.
    could dirty injectors or bad 02 sensor be the culprit without throwing a code because those probably need to be changed?
    Is motronic capable of detecting a misfire?
    1989 BMW 325is Lachsilber metallic 5 speed
    2007 BMW 335i KARMESINROT 6 Speed manual
    2011 BMW X5 35I
  • Kevinl
    • Oct 2012
    • 897
    please move to M20 forum not sure wtf happend
    2011 BMW X5 35I
    • mpowerful
      • Jul 2013
      • 1273
      Its in neighborhood of 2000-3000 cold and 200-300 hot.
      The other things wont throw coolant temp code but could cause shitty running. Motronic cant detect a misfire.
      • justin_l_
        • Jun 2007
        • 1079
        Could be a wiring issue. If sensor is good, I would check the wire for wear and tear next.
