Safe to delete SAP wiring/relay?
  • justin_l_
    • Jun 2007
    • 1079
    I've read yes and no. Looking at the ETM I don't see a reason why I can't. Am I missing anything here that will bite me in the ass?
  • 328ijunkie
    • May 2007
    • 3961
    Assuming it's flashed out of the ecu, yes.
    In most cases it's safer too as in some circumstances the ecu will back feed the signal to the second pin 87 on the relay and smoke the ground wire all the way through the harnesses. I remove all accociated wiring on all the swap harnesses I do
    Check Us out on Facebook
    Full Product Line Tuning
    • Mistawall
      • Dec 2013
      • 319
      is it recommended to delete the SAP? is there any benefit to keeping it? i was thinking of just leaving mine on but maybe i should have it deleted?
      my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
      • 328ijunkie
        • May 2007
        • 3961
        Benefit of keeping it? Not really.
        Safe to delete, yes. Car isnt going to explode or anything.
        • justin_l_
          • Jun 2007
          • 1079
          Ok, good to know. One less thing to try and stuff under the harness cover.
          • 328ijunkie
            • May 2007
            • 3961
            Secondary O2s and running losses also can go assuming theyre punched outta the ECU :P
            • justin_l_
              • Jun 2007
              • 1079
              Got rid of them, what about the 6031 connector. I powered pin 8 so I could reflash the ecu through the diag port, but other than that is there any reason to keep it?
              EDIT
              Going through the ETM the only thing I'm not really sure of is pin 10. It says two different things on two different pages. Page 161 it says pin 10 is for VSS, on page 220 it says it if for oil temp. *This is using the wedphones ETM's for a 99 e36 328
              Pin out for X6031
              1 CEL
              2 Carbon Canister
              3 Cluster X17 connector
              4 OBD2 Connector
              5 Fuel Tank Sensor
              6 Fuel Tank Sensor
              7 Fuel Tank Sensor
              8 Power for Diag port
              9 NA
              10 See note above
              11 NA
              12 NA
              • MyE30
                • Sep 2013
                • 326
                justin, x6031p10 goes to the e36 cluster x16p13 which is indeed the oil temp sensor. it's for e36 clusters with an oil temp gauge vise the stupid mpg gauge.
                • MyE30
                  • Sep 2013
                  • 326
                  Also, i didn't get a chance to check your references; however, make sure the pinouts you are looking at are not in the "318is" sections as it will cause confusion. take a look at page 161 and make sure it is/is not referring to the model you are dealing with.
