s52 Auto DME and Manual DME is there a difference?
  • Mistawall
    • Dec 2013
    • 319
    like the title says. is there a difference? i want to send my dme out to get flashed. so i just want to be certain.
    my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
  • DesertBMW
    • Aug 2011
    • 1043
    ECUs are the same the software is different.
    • kronus
      • Apr 2008
      • 13032
      you can get an ecu that came out of an auto reflashed to think it's for a manual car. the hardware is identical.
      cars beep boop
      • 328ijunkie
        • May 2007
        • 3961
        Hardware same, flash is different. They can be flashed to either however
        Check Us out on Facebook
        Full Product Line Tuning
        • MyE30
          • Sep 2013
          • 326
          Originally posted by desertbmw
          ecus are the same the software is different.
          Originally posted by kronus
          you can get an ecu that came out of an auto reflashed to think it's for a manual car. The hardware is identical.
          Originally posted by 328ijunkie
          hardware same, flash is different. They can be flashed to either however
          qft
