I've been a member for a few years on here but not posted much and figured I would post my swap on here as an intro. It is copied from another forum so may be a bit choppy…….
I've been wanting to do a swap for a long time. A little background on the car, it's a 1991 325i four door 172,000 km when I bought it three years ago and its now got 176,000km. Since i bought it I have added a 373s diff, e36 steering rack, new control arms, tie rod ends, offset CABs, Bilstein sports, Vogtland springs, IE camber plates, adjustable swaybar links, stainless brake lines, rebuilt calipers, Hawk HPS pads, Brembo blanks......
I've taken care of most of what you can't see and now its time to start under the hood.
Out with the old
Pretty dirty under there
Getting better
Then came a delivery from Bimmerparts! M52B28 with 60,000km on it!!!
Pulled off all the OBD2 junk
Cleaned it up a bit
Then I got a few goodies
gaskets metal thermostat housing etc
Clutch
water pump
Shiny stuff
I started cleaning up the engine bay
But decided I didn't want all those wires in sight
Or all of the brackets
so I decided to clean things up some more
changed the valve cover gasket
New nuts for the exhaust studs and this is how she sits right now
Tomorrow if I can make the time I am hoping to install clutch, bolt trans to it and maybe drop the engine in. :beerchug:
Out with the old
Getting better
Cleaned it up a bit
Clutch
water pump
Shiny stuff
