1986 325es, m50tu swap with S50 cams and turner chip.
So I had my swap in and running great until my pressure plate exploded. Since I couldn't get the trans out separately, I dropped the subframe with the motor and trans all together to fix it. Now I put it all back together and I have a crazy idle issue.
It will start right up and idle up and down from 1500 to 3500rpm. When I disconnect the MAF, the idle will smooth out.
Things I have checked so far:
-vacuum - smoke test was clean
-icv - cleaned and tested, vibrates when running
-MAF - cleaned and tested
-Wiring - all looks great, like I said it ran perfect before and nothing was done to the wiring in the process of taking the motor back out
Has anyone seen this before? My search yielded only one other issue and of course the OP never reported back to state whether or not the issue was resolved.
I appreciate any help you guys may have. Since I suck at internet, I have posted a link to a youtube video below. It was on my phone and I am working solo so I apologize for the quality.
Link: https://www.youtube.com/watch?v=KB0M...ature=youtu.be
Thanks in advance! This is literally the last thing I have to do before having the exhaust welded back up and installing AC.
