So I had a bad fuel pressure regulator on my s50 swap (car was running sweet until the FPR started leaking fuel into the vac line...
Ran the car and pulled fuse 11 to kill the pump to get the engine to use the fuel in the lines and drop the pressure (immediately replaced it and disconnected battery). Disconnected the feed and return lines and the vac to FPR, got the fuel rail out and put in a new FPR.
Put it all back together and connected fuel lines back up but now when I turn ignition to accessory I get no fuel pump prime and no fuel when i crank.
Checked all fuses and none blown and tried a known working fuel pump relay from my other car and no go. Bridging pin 30/87 on the fuel pump relay powers the pump and the FPR holds pressure...
Is there anything I can have knocked/disconnected that would cause this no fuel issue? Checked crank sensor and its still plugged in all good and is only 2 months old...
