Radiator Choices M20, M50 or M42?
  • amcink
    • 788
    What to use for an M50 swap and which one will provide more space for the OEM fan clutch.
    Also How do I attached these (M50 and m42) to the body?
  • justin_l_
    • Jun 2007
    • 1079
    M50 radiator is the same as a late model m20. It rests on the radiator support on the bottom and the top has a bracket the bolts to the top of the radiator support. I'm not sure on the m42. They all have the same clearance afaik.
    • mpowerful
      • Jul 2013
      • 1273
      Use euro diesel fan. It give nearly same clearance as stock. 5-8mm or so.
      • Mistawall
        • Dec 2013
        • 319
        I plan on using my m42 radiator
        Sent from my SCH-I545 using Tapatalk
        my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
        • e30austin
          • 15382
          If you don't give a shit about your head gasket or cyl head, use an M42 radiator. If you do, get a real radiator (M20, M50, Z3M, etc) and be done.
          • justin_l_
            • Jun 2007
            • 1079
            If you are in a warm climate stay away from the m42 radiator. Personally I love in maine but still run a mishimoto e36 rad.
            • amcink
              • 788
              part number for the diesel fan and the clutch used on your swap _ I just saw the link and I like it
              • mpowerful
                • Jul 2013
                • 1273
                The clutch is same as basically everything else. Mine was new on shelf so i grabbed it but it was for an e39 540i. The e36 or m20 clutch will work. The fan pn is 11522243303. I got it from thebmwpartstore.com for 65 shipped which is about cheapest i could find it new.
