injecters and brains
  • m3needer
    • Jan 2006
    • 21
    im putting a m50 from a e34 in my e30 can i put a brain from a 95 m3 in it instead of the original brain ,,,and are the injecters diferent for m50s than S50s if they are will those need to be swapped as well..... id put a S50 in it if i had one available at the moment
    thanks
  • FredK
    • 14762
    S50 and M50 injectors are the same green top Bosch 17.5 lb/hr units.
    What year is the DME (brain) from? If it's from 1992 you definitely cannot use it. If it is 93-95, then you can use the DME, ONLY if you swap out the chip for a stock M50 chip.
    • m3needer
      • Jan 2006
      • 21
      its a 1994 525i 5speed car
      • MrK
        • Jan 2006
        • 709
        I'm not quite sure why someone would swap out an s14 for an m50. Am I the only one that finds this weird?
        This is your M20 on steroids:
        • FredK
          • 14762
          Hahaha, so true MrK!
          • 1990m3
            • 1180
            thanks
            pray tell what your plans are besides a loss in performance and handling.
            A well maintained S14, even slightly modified is much more fun to drive than an M50 and probably a good bit quicker too.
            • m3needer
              • Jan 2006
              • 21
              im using the m50 until i find a s50
              but the m50 is also being used as a test motor to make sure the wiring is correct and the exaust manifold is modified accuratly ,etc...
