Trans and clutch questions,may be urgent!
  • Aguedae30
    • Jun 2013
    • 68
    Hi everyone,
    yesterday I blew another g240,the second one, on my m50 w/m20 flywheel and clutch,I don't feel like blowing another one so I'm going g250,so here come the questions:
    -Can I use my m20 flywheel,starter,clutch,throw out bearing with a g250,just swapping the transmission?
    -I know that a 325is e36 cross member will be the adequate length,what other modifications will I need to make it fit correctly?
    -Which shift linkage will make the job? custom?
    I'm in a little hurry,the car must be running on wednesday
    Thanks in advance!
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    ― Jeremy Clarkson
    Euro 318is M50 build thread
  • Nick_S
    • Apr 2011
    • 3655
    I can't definitely answer your question about the starter/flywheel/clutch fitting but I'm nearly positive you use the stock G250 linkage. Another thing to consider is this trans has different ratios than the 240. If you're still running the stock 4:10 rear end you're going to be turning some pretty high RPM's at highway speed.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • Aguedae30
      • Jun 2013
      • 68
      Yes,I have a 3,64 lying around for the duty ;)
      thanks for the response!
      ― Jeremy Clarkson
      • drulle
        • Dec 2008
        • 1906
        I used 323i TOB on my last M50/G250 swap w/m20 single mass Flywheel/Clutch/PP
        It is a little taller (5-7mm) IIRC
        "i love vee tek, its a wonderful sound when you driving right by it"
        If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulle
