Low Voltage @ Stater Solenoid (car wont start when hot)
  • Tchao
    • Apr 2007
    • 223
    Hey guys Ive been having weird starting issue lately.
    The car will crank (and start) just fine when its cool out, or if I park in the shade.
    Now that its 110F in Phoenix, my car will not crank. Solenid will not even engage at all...
    Car will sometimes start with a jump, and its needs a vehicle jump, not a starter battery box crap.
    Replaced battery and not the problem.
    I just recently tested the voltage at the c101/x20 starter-wire and when key in CRANK-position I read 8v
    What could be causing such low voltage...is my key switch/tumbler going bad and dropping voltage when the car is 150F+ inside the cabin and not sending enough power to solenoid?
    Thanks in advance R3v guys,
    -San
  • whodwho
    • Jun 2008
    • 1547
    Mine has the same issue, only when really hot and will start with a jumper wire at the diag connector. I keep a jumper wire under the floor mat for quick access
    I think it is the voltage drop thru the ign switch that aggravates it. Instead of replacing it I am going to use a relay at the starter so the ign switch just triggers the relay. It's an old aircooled VW trick as they were notorious for that 8^)
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • Tchao
      • Apr 2007
      • 223
      Im thinking of doing that too...But really just want to solve whats causing it :(
      The weird part is that after sometime of trying...maybe 10mins later, the car will just start with a normal turn of the key. Like today...after a few no starts and testing of the c101/x20 all of a sudden the damn Pins gets 12.5v and the starter turns. No there goes more diagnostics work....gotta wait until it messes up again.
      • whodwho
        • Jun 2008
        • 1547
        I think replacing the ign switch will fix it, I think the old ones get bad connections from the contacts arcing under load.
        • spdracrm3
          • Sep 2009
          • 959
          voltage drop test
          just do a voltage drop test across the ign switch , any more than a tenth of a volt drop you need a new switch. you can voltage drop the entire circuit back to the battery to find which component/connection is causing the problem (just takes the time to access all the connections and have problem occur while your testing )
          first page in all the ETM's gives various testing procedures including voltage drop test....
          Angus
          88 E30M3 X2
          89 325IX
          92 R100GS/PD
