Noobie Questions Help!!
  • TapOut
    • May 2011
    • 112
    i know these are some noob questions but i cant seem to find answers. im swapping a m50tu into my 88 325is auto.
    what driveline would be the best and cheapest option? and guibo?
    since my e30 is a auto, can i use the pedals from the e36 to swap it to manual?
    im going to be using a zf trans with a Luk clutch kit from a 98 m3, will i be able to use the original m50 flywheel?
  • MR E30 325is
    • Dec 2008
    • 3299
    Match your driveshaft to the transmission you are using. Since you are going to use a ZF, you need a 328 5 speed driveshaft. Guibo will need to match the ZF as well.
    Which I happen to have for sale, if you want it. PM me.
    Not sure on the pedals.
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
