I was putting a rear seat in my car and tightening down the rear seatbelt bolt near the battery cable coming from the trunk and the washer on the bolt nicked thru the jacketing - this in turn shorted the cable out and melted the fusible link in half between the bolt and the battery before I could disconnect it. It seemed like no damage was done "downstream" past the short so I thought nothing of just getting a new cable which I ran today and hooked up with the battery (aside from the subsequent small trunk fire and near heart attack when it shorted).
When I got it all hooked back up today, I turned the key everything seemed fine (though my cluster doesnt currently work) the check engine light came on as usual when the key was turned, then I cranked it and it turned a couple times, then everything went dark. Now Ive got nothing and no combination of cleaning terminals or playing around with either end of the cable that I replaced has given me anything.
Any ideas? Is there something that could have gotten fried I should check on? I put this in this subforum since its on my M52 swapped car on which the harness was spliced (no adapter used) just in case it matters...I looked around and didnt see anything obvious yet. Just seems weird since it was "OK" enough to crank a couple times then lights out...
