About to E28 M5 mounts..right part number/price?
  • Drew325is
    • Oct 2004
    • 520
    Hi Guys,
    I'm about to order a pair of E28 M5 rubber engine mounts for the M52 swap, and here's the part numbers and prices. Do they look correct?
    1x 11811128932 Left - $22.00
    1x 11812225201 Right - $43.00
    I just want to be sure before buying. I used realoem to get the numbers...but I'm not entriely sure I've interpretted the descriptions correctly.
    Many thanks,
    Drew.
  • C ///M
    • 1040
    Just get the later E28 535i mounts. The later 535i mounts are exactly the same as *one of the E28 M5 mounts, I forget if its the left or right. The M5 mounts are actually different between right and left, whereas the 535i mounts are the same for both sides.
    I don't quite remember becaues it's been a long ass time, so I'm not 100% sure.
    332iS R.I.P.
    • DEV0 E30
      • Oct 2004
      • 8903
      I didn't know the part # off hand, Orca says:
      Mounts (2) 11 81 1 132 793
      @ BMA
      • Drew325is
        • Oct 2004
        • 520
        I think what's getting me confused is that there's the green ones that orca uses (linked to by Devo_E30)...and then there's these: http://www.bmaparts.com/epcvsoapimc....entid=bmaparts
        The latter being the E28 M535i mounts....which appear to just be black rubber cylinders...not those whacky green ones.
        C///M what you're saying about the 535i mounts being the same as one of the M5 mounts sounds familar from digging around on the parts CD.
        So I guess if I just order a pair of the 535i mounts I should be safe.
        • joshh
          • Aug 2004
          • 6195
          Those are the right nubers. I just verified with the dealer. Even though they have them listed on the wrong side from each other.
          I ordered the 533i mount on one side and will use a 5mm spacer because it only cost 18 bucks compared to the 47.00 M5 mount.
          "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
          ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
          • bmws50b30
            • Aug 2005
            • 1151
            from realoem.com
            the numbers chris posted are for
            E28 535i SEDAN, M30, AUTO (DC84)
            E28 535i SEDAN, M30, MANUAL (DC74)
            1991 330is
            • 325Projectz
              • Jan 2005
              • 1956
              You may have saved money, but my guess is those mounts you got aren't as stiff...
              91 m3
              • joshh
                • Aug 2004
                • 6195
                That's ok for a while. John the guy making the Urethane mounts is supposed to come through soon.
                • Beej '86 325es
                  • 2639
                  I forgot about that, is there a current thread somewhere that I can check for updates?
                  -Brandon
                  '86 325es S50
                  '12 VW GTI Autobahn DSG
                  '03 540i M-Sport (sold)
                  '08 Jeep SRT-8 (sold)
                  For sale:
                  S50 TMS chip for Schricks
                  • 325Projectz
                    • Jan 2005
                    • 1956
                    I would grab a set of Urethane mounts from him...
                    Also, anyone here run stiff/urethane tranny mounts?
                    91 m3
                    • joshh
                      • Aug 2004
                      • 6195
                      I've been waiting for a while but he's pretty busy. I keep bugging him but that doesn't always work.
                      I have a thread on it....looking.
                      • gjuu
                        • Jan 2005
                        • 78
                        I am also confused......which one is it.....number "1" or number "2".... or either... or one of each :)
                        Can we get a show of hands here or some other kind of consensus......
                        • 325Projectz
                          • Jan 2005
                          • 1956
                          I have #2. Both sides.
                          91 m3
                          • joshh
                            • Aug 2004
                            • 6195
                            One of each will also work. The Green mount is the stronger one and should be on the drivers side.
                            • Brew
                              • 3060
                              #2 both sides. Spaced up about 1/4" for oilpan/steering rack clearance. Guessing this is an airbag car issue- I didn't need any spacers on my '89 325is.
                              '91 318is
