rewiring the engine harness
  • e-dirtym52
    • Aug 2012
    • 338
    i'm cleaning up my wiring harness and rewiring my c101. i can't remember what wires went where but all of my wire colors on the body side are different than what i can find. so is the pin assignment still the same if the wire color is different than what i can find? such as how pin 14 is typically black/white and mine is a blue/yellow?
    here is the pins for the body side c101:
    1. blue
    2. blue/black
    3.-
    4. brown/violet
    5. black/brown
    6. green/yellow
    7. green
    8. yellow/white
    9. black
    10. violet/green
    11. white/blue
    12. brown/black
    13. violet/red
    14. blue/yellow
    15. black/green
    16. white/black
    17.-
    18. black/yellow
    19.-
    20. red/yellow
    any info helps on what which wire is what. thanks
    If you're not going to do it right, please don't take it out on your car!
  • e30rapidic
    • 2167
    have you looked through the ETM for your year?
    '87 325ic, powered by S50.
    • e-dirtym52
      • Aug 2012
      • 338
      I have it up on my computer now. I just haven't had the time to look through it and was hoping someone could have some answers on here. Plus I'm not very savvy with that stuff.
      • justin_l_
        • Jun 2007
        • 1079
        What exactly are you rewiring? Redoing an adapter or redoing the body side of the c101 itself?
        • M3PO
          • May 2012
          • 537
          Mine where almost all different colors than what most people listed but served the same function which is why you gotta go by pin number.
          • e-dirtym52
            • Aug 2012
            • 338
            i'm redoing the engine side. the body side wires are different than what usually comes up but if the pin numbers serve the same function then that's all i need to know. but engine side comes from an e34 525i and i lost how i pinned it before and my mistake i didn't write down how it was before i took the pins out
