Fellas,
Does anyone know what length selector rod is used (and I guess shift carrier too) when using the ZF 5 speed box on an M52 swap? I am looking to get a UUC DSSR, and also currently deciding on an M52 swap (from 325i). So ideally both are the same, but it doesn't look to be the case. Can I safely assume you need to use the same selector rod/shift carrier as the transmission came with?
Cheers,
Gus
Cheers,
Gus
i have no idea what i am doing with my life
