running lean and lack of power, I need your help
  • RVA e30
    • Jan 2006
    • 140
    hey I dynoed my car today and am very dissapointed in he results.
    I go 178 rwhp and 198 ft/lbs of torque
    picture of dyno graph
    mods on the car are...
    S52 engine
    M50 intake manifold
    24# injectors
    chuck stickley chip
    euro HFM
    intake
    8.5 lb flywheel M5 clutch
    3 inch exhaust all way back (in preparation for turbo in future)
    I posted a link because the picture is pretty big
    i did a compression test today after the dyno and the results are:
    200
    195
    195
    170
    195
    192
    anybody have any ideas what the deal is?
  • SchnellerVert
    • Sep 2005
    • 3948
    What's up with number 4? the other numbers are good but 4 is not good.
    Is the software burned for compatibity with the mods ie the larger HFM and injectors? Your picture was hard to read I could barely make out the writing and could not see the AFR scale.
    • RVA e30
      • Jan 2006
      • 140
      yeah the chip is made for all the mods I have
      I will scan in the pic tomorrow when I go to my moms for easter. I just had to take a picture of it since thats the best I could do for tonight.
      cylinder 4 has been like that for a while, It dynoed at 217 to the wheels and 220 ft/lbs of torque when it was in my e36. do you guys think something could have happened when it got in the wreck?
      • 325Projectz
        • Jan 2005
        • 1956
        Compression is low. Have you done a leak down?
        91 m3
        • 1990m3
          • 1180
          vacuum leaks? how's the idle?
          • RVA e30
            • Jan 2006
            • 140
            idle will sometimes fluctuate, to slight revving up and down
            I talked to my friends dad who is a bmw tech and he said that even though the compression is low in that one cylinder it shouldnt be that low hp.
            I am going to do a leakdown test, but my friends dad told me to get a fuel pressure gauge first and make sure that I have good fuel pressure.
            I also posted a better pic of the dyno graph
            • PУCCKAЯ_e30ka
              • Jan 2006
              • 1226
              something messed up in wiring/ignition?
