m50tub25 injectors not pulsing
  • zachpepper
    • Aug 2012
    • 9
    i need all the help i can get. im out of ideas. i have a 95 obd1 m50tub25 with a red label 413 ecu in my 91 325i. my grounds are good and my power wires are good. when the injectors are plugged in both the red/white stripe wires, and the brown wires have power. i have the fuel pump wired to a switch so its getting fuel in the rail just not pulsing. iv tested both of my ecus and they both work.
    someone please help!!!!!!!!!!!!
    @Pepperede30
  • Nick_S
    • Apr 2011
    • 3658
    Replaced you're crank position sensor? Mine ohm'ed out just fine but wouldn't start. A brand new one cured it and fired right up.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • zachpepper
      • Aug 2012
      • 9
      yea i have 3 of them but there all used. there probably all bad.
      @Pepperede30
      • Nick_S
        • Apr 2011
        • 3658
        Try a brand new one. Even if its not your issue, it can't hurt to replace it and eliminate the variable.
        05 Honda Pilot
        24V swap thread
        • goarmy
          • Nov 2011
          • 622
          Before you buy a new one, is your ecu case bolted down?
