I just swapped my m10 with an m50b25tu. It idles around 1000 rpms and does fine under about 3k rpm. However when I go over 3k or mash the throttle my car goes nowhere. I cleaned the icv ohm'd out most of the sensors, checked for vacuum leaks cleaned out and replaced the maf 3 times(used). I checked codes and it only brought up a maf code. If theres a big enough vacuum leak could it throw a maf code? Has anyone ever experienced this or have ideas on what it could be? Or where there might be an obvious vacuum leak I could've missed?
Is it fuel pressure related?
I've also heard not wiring the vss right could put it into a limp mode. On the 84 the vss wiring is in a different spot. I had it connected pin 14 on x20 to the green wire under the dash on c104.
Any help would be greatly appreciated. Its my only car and I need to get it back on the road. My girlfriends getting tired of me driving her 325e.;D
