1984 318i m50b25tu swap poor acceleration limp mode?
  • shipwr3k
    • May 2014
    • 3
    I just swapped my m10 with an m50b25tu. It idles around 1000 rpms and does fine under about 3k rpm. However when I go over 3k or mash the throttle my car goes nowhere. I cleaned the icv ohm'd out most of the sensors, checked for vacuum leaks cleaned out and replaced the maf 3 times(used). I checked codes and it only brought up a maf code. If theres a big enough vacuum leak could it throw a maf code? Has anyone ever experienced this or have ideas on what it could be? Or where there might be an obvious vacuum leak I could've missed?
    Is it fuel pressure related?
    I've also heard not wiring the vss right could put it into a limp mode. On the 84 the vss wiring is in a different spot. I had it connected pin 14 on x20 to the green wire under the dash on c104.
    Any help would be greatly appreciated. Its my only car and I need to get it back on the road. My girlfriends getting tired of me driving her 325e.;D
  • THEhomelessONE
    • Oct 2013
    • 303
    Weird that it idles so high, I've got the same motor and idle at 600~rpm. Ever take the intake manifold or injectors out? Wouldn't hurt to have the fuel pressure checked, only problem I had was a bad fuel relay. GL
    RIP 02/25/15
    http://www.r3vlimited.com/board/show...16#post4356816
    • N-Gen
      • Mar 2013
      • 97
      It might not be a case to be concerned about the idle rpm especially if the ECU chip was changed. I've swapped mine with a ~800rpm idling one and I've seen 1000rpm+ ones being marketed as aggressive chips.
      I can't give any input about this issue though since I've not swapped mine yet and have no clue what could happen.
      • justin_l_
        • Jun 2007
        • 1079
        The idle is bumped up for tunes with light weight flywheel and or cams usually.
