24v swap transmission+diff. question
  • 4door30
    • May 2014
    • 155
    I have been reading through this forum quite a bit lately since I am trying to sell my e36 m3 in order to fund my s52 swap into my '90 325i... I have read about all of the transmission/diff./driveline options but I am wondering about real-world experience on how people like the setups they have...
    1. In your opinion is the zf trans from an m3 better for the swap than the g260 in my e30 stock and why?
    2. Based on the trans you have, what diff. did you choose and how do you like it?
    3. I am confused with the driveline setups... I heard about using an e36 328i driveline for a zf trans... So just the stock driveline for a g260? And which is better?
    Thanks in advance!
    ~ Griffin
    Want shirts, stickers, or any other custom screen-printed or digitally printed apparel and posters?
    Check out my website! --- www.weareforte.com
    Forte Creative
    Griffin Hardcastle
    griff@weareforte.com
  • agent
    Vice Grand Pubaa
    • 7960
    Yes. No overdrive 5th gear; does not necessitate bending the selector rod and/or buying an aftermarket support bracket; built to hold more power; newer.
    A 3.15 Torsen. It's perfect for how I use the car, which is primary AutoX, mountain/twisty road carving and otherwise beating the crap out of it at every opportunity, with an occasional road trip in the mix.
    Yes, you'll need a "late" E36 ( 96-98 ) drive shaft out of a manual transmission car if you use the ZF.
    Originally posted by kronus
    • 4door30
      • May 2014
      • 155
      Thanks for the response! So in my e36 m3 right now, I swapped to a 3.38 ratio and the car rips... Does it just not equate the same way in an e30? If I ran an s52, zf m3 trans, and 328i driveline, wouldn't the 3.38 have the same effect? Or even the stock m3 diff. 3.23?
      Again, thanks for the help, this is my first e30 and I couldn't be happier.
      Forte Creative
      Griffin Hardcastle
      • agent
        Vice Grand Pubaa
        • 7960
        It would, though an E36 diff won't bolt up to an E30. You'll need to source an E30 diff unless you plan on swapping the internals (yourself).
        How you're going to be using the car will determine the diff ratio you'll want. You may want to go with a 2.93 for mostly highway use; a 3.73 will be a lot of fun until you try to go faster than 70 for more than a straightaway. Somewhere in between is typically the sweet spot. Whatever ratio you choose, you'll definitely want an LSD or a Torsen.
        • 4door30
          • May 2014
          • 155
          Thanks for the input, sounds like staying right in the middle of that will be the best idea for me...
          Forte Creative
          Griffin Hardcastle
          • M3PO
            • May 2012
            • 537
            I have the ZF from an E36 328i in mine with a 325es "big guibo" driveshaft and a 3.25 40% lockup LSD from a 6-series (I think it's from a 635csi). I'm using the E36 M3 shifter. I was basically trying to mimic an E36 M3, but lighter. I like it a lot. Only thing I'm not too find of is spinning ~3750 RPMs at 80 mph (205/40/16 on there now).
            • mpowerful
              • Jul 2013
              • 1273
              My opinion leans the other way and ill explain why i decided to stay with g260. First and foremost i am cheap (not stupid though). G260 is plenty strong and should easily handle n/a s52 power even. No need to buy another tranny, a driveshaft, or a diff. Those are expensive ventures....much more expensive than buying at minimum a 70 trans brace. Anyway bending the shift selector rod takes about two minutes and is essentially a very minor tweak. Also you can use m20 single mass flywheel. It has to be cut down on backside to clear oil pan bosses which cost me 40 bucks with the benefit of going down to 14lb flywheel. Clutch can be a potential make/break too though. The stock m20 clutch is weaker than stock zf clutch setup. Many people run an aftermarket setup. Ive been on stock setup 3000 miles now with no issue but when i do have to replace it i am going with the m3 disc and pp which is plenty strong and nearly same price as m20 clutch kit.
              • butters
                • 1202
                Everything agent said.
                I would have gone for the ZF anyway (I think) but it came with my S50, and I also have a 318 so I never had a G260 to begin with.
                I went with a 2.93 LSD because it's relatively easy to find, and I wanted to start out with taller gearing and see how it went rather than going with 3.25 or above and then wishing I had less revs on the highway. I don't like cruising above 3000 rpm (weird mental thing, idk), and I'm happy with the gearing because that puts me at 75 mph indicated in 5th. I'll be pursuing a rebuild on the diff, so I've had to think about it and map out my options of speed/rpm in a spreadsheet, and at this point I plan on staying with that ratio.
                • 4door30
                  • May 2014
                  • 155
                  It's good to hear all of the actual situations people are in with their builds... So far I'm looking at s52 (staying obd2), zf320 trans (e36 m3), 328i driveline w/e30 csb, and either a 3.25 or 3.46 diff... The main reason I want to possibly go all the way up to a 3.46 is because I am usually around town or cruising at no more than 65 all day, I'll have a chance pretty soon here to drive an s50 e30 with a 3.25 so I will for sure make my decision after that!
                  Thanks for the help guys, I appreciate it.
                  Forte Creative
                  Griffin Hardcastle
                  • Wanganstyle
                    • 2828
                    My daily grocery special is a 1998 m3. Stock DME and 100% original engine
                    I fit a 3.46 final drive; I have every option avail on my shelf.
                    My 2002 325i-5mt e46 also had a 3.46 fitted
                    a 100% s52+5 speed + 3.46 final = 23MPG combined.
                    With 3.23 it's about 24-25mpg combined at best. Never going to get much better
                    IF the swapped e30 footwork is not corner balanced well you won't be able to put down the power.
                    Stock e36m has a 3.23 and it's pretty much spot on for 95% of people. Don't buy a Hella old rotten 3.25 from a dirty e28, buy one from a modern z3 or order one custom built if the budget is there.
                    • 4door30
                      • May 2014
                      • 155
                      Yeah so far I'm looking at either a 3.15 lsd or a 3.25 lsd, and if I'm swapping the diff, either it will be rebuilt before I buy it, or I will rebuild it myself.
                      Forte Creative
                      Griffin Hardcastle
                      • zcenterb
                        • Feb 2014
                        • 2105
                        It think it depends too on whether your running an S50 or an S52. I know that the S50 (1995 M3) came stock with a 3.15 diff, while the 96 and later came with a 3.23. I know they are different engines and everything but after driving my buddies 99 M3 for a month or so, i did like the power it gave out with the stock 3.23 but just wished it would spool up through the gears faster... like with a 3.46 or something. So in my S50 swap i wanted to go higher than the stock (3.15 for a 95 s50 engine) to try and get that, so I'm going with a 3.25 torsen or LSD. Plus I'm in Vermont, so road are windy and hilly and more fun up here.
                        CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
                        Instagram: @centerbarmotorsport
                        Facebook: https://www.facebook.com/centerbarmo...?ref=bookmarks
                        The Fleet:
                        -1984 325ei Lapis
                        -1991 325ix Diamond
                        - 2005 X5 4.4i Black Sapphire
                        -1972 2002tii Fjord - SOLD 7/8/17
                        -1991 325i S50 ///Sterling Silver/// - SOLD 9/15/17
                        The Bike:
                        -1980 R100RS Inca
                        • Wanganstyle
                          • 2828
                          The smaller engine will only desire an even shorter gear.
                          3200cc > 3000cc with lower brain processing power.
                          There is a really good reason all the serious e36m3 track cars in norcal are going to 3,91 final drives; they all need it for elevation.
                          • 4door30
                            • May 2014
                            • 155
                            Yeah that would make sense why the s52 is AMAZING with the 3.38 diff. rather than the stock 3.23. I did that diff. swap in my e36 m3 and the car rips...
                            Forte Creative
                            Griffin Hardcastle
                            • Roysneon
                              • 4505
                              I run an m50 with a ZF behind it and a 3.73 diff. It's fine for city driving or even highway. Top end speed is pretty limited, though. I hit rev limited in 5th gear at about 195km/h when I had 225/45R17 tires. Now I have 215/40R17, I'm sure top speed will be even a bit lower.
                              Originally posted by mbonanni
                              I am a pursit now.
