Not sure of your exact needs; here is some data that might be useful though
Ran the m52 in anE30 chassis for 52hrs till failure
Failure point was valve spring retainer cracking and collets pulling through
Valve dropped destroyed piston and head.
Rpm limit was set to 7500 with an aftermarket chip; stock I believe is 6500
Solid aluminum aftermarket engine mounts were also ran; these had a lot of nvh and the oil pump Pickup was breaking down at the casting seams.
if was to build one myself today I’d probably use new stock s52 valvespring and retainers; supposedly they are more updated for the cams and rpm max of the s52.
Wpc all the moving parts and oil pump bits
Run stock ecu and rev limit for more durability
