Another M50 no start thread
  • Eatmyfrenchfry
    • Sep 2014
    • 2
    Recently pulled the m42 from my 91 318is and dropped in a 95 m50 with zf trans. Got everything all wired up correctly as far as i know, grounds are good. Hard wired the harness (no adapter). She cranks over fine, starts with starting fluid so i know its getting spark. Problem is i can't get fuel to spray from the injectors, fuel feed is hooked to the front of the rail as it should be. Tried a new crank sensor but still nothing. Been wasting too much time in the garage trying to get this damn thing running. Help would be greatly appreciated
  • e30austin
    • 15382
    Sounds like your fuel pump is set to the wrong pin. I would look over the C101/X20 wiring again. 318i are different than 325i.
    '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
    • Rdreas
      • Aug 2013
      • 164
      So in 95 they started remote mounting the fuel pressure regulator. This caused a crank no start for me. There are 2 ways to verify this; look on the back of the fuel rail for the circular thing hanging down, and you can also put a pair of vice grips on the return line and see if it starts. If it does you need a fuel rail from a pre 95 m50
      • Rdreas
        • Aug 2013
        • 164
        http://m.ebay.com/itm/131269270255?nav=SEARCH like this one. They have gone up in price so maybe try a local junkyard and don't waste $80 on this one
