running super rich
  • e-dirtym52
    • Aug 2012
    • 338
    running super rich
    Obd1 m52 running 21.5 injectors and I'm running incredibly rich. Put in New pump and Fpr and still runs super rich. Trying to lean it out thinking a tuning bug might be an issue I put in 17 pound injectors and it runs incredibly lean. I've tried looking for vacuum leaks before with no luck but I'm going to build a smoke machine and make sure there's nothing because that's about the only thing I can think of unless anyone can think of anything else to check?
    I'm trying to borrow an afm as well to see how rich she's running
    If you're not going to do it right, please don't take it out on your car!
  • sweet3
    • Oct 2012
    • 752
    I would say its a tuning issue. I'm having the same problem right now. I'm about to purchase a chip from "sssquid" soon.
    The obd1 ecu is tuned for 17lbs, but your engine needs 21.5 to be stock. I think a good option is to put a correctly tuned chip in your ecu.
    Hope this helps!
    PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
    • e-dirtym52
      • Aug 2012
      • 338
      That's what I have is squid. Awesome product. I'm not totally sure if a vacuum leak can make such a big issue without it being completely obvious but I still think I'm going to use a smoke machine just to be totally positive there's no vacuum leaks happening. You never know
      • 328ijunkie
        • May 2007
        • 3961
        Vac leaks cause lean running...
        Check Us out on Facebook
        Full Product Line Tuning
        • e-dirtym52
          • Aug 2012
          • 338
          yea i know i just didn't know if that would lead to other issues or something. trying the green injectors was basically just an experiment. wasn't really expecting it to fix all the issues but just seeing what exactly would happen.
