Which FW/Clutch on G250 + M52 (just need to this drive my swap)
  • E30Runt
    • Jul 2013
    • 46
    Last thing to resolve before I finally get to drive my swap!
    First I'm stuck with this G250 (on M52) so please don't be critical.
    2nd the shop that installed it put an M3 FW and Clutch and it's scraping the bellhousing.
    I researched and could not find a definitive answer on which FW/Clutch to use. I read use of any as long they are matched. I read TOB has to be in a from a 323 Euro. Info is just everywhere
    Can anyone tell me definitely what to use as the mechanic that I worked with doesn't know?
    The mechanic went and ordered a Sachs 328 clutch already for me. Not sure if that's right. When I go to order online it shows that 323 through M3 all share the same combo which totally confuses me.
    Thanks in advance for the help!
    1984 AW 318i - aka Runt
  • justin_l_
    • Jun 2007
    • 1079
    With a getreg 250 I used the 92 325i clutch and flywheel.
    • DesertBMW
      • Aug 2011
      • 1043
      I used 96 328i clutch and flywheel with my G250 and it works fine.
      • drulle
        • Dec 2008
        • 1906
        On my old car (M50NV with G250) I used m20 single mass flywheel (shaved down on the back side), m20 clutch and PP, 323i euro throw out bearing. This setup works great, less expensive and lighter then e36 stuff. Good luck
        "i love vee tek, its a wonderful sound when you driving right by it"
        If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulle
