16w Engineerings shop car
  • shocwav3
    • Apr 2014
    • 69
    #31
    Originally posted by Cinnabar325is
    haha, at least I know my curiosity concerning throttle plates is justified.
    Funny, I spent time on the two Hardinge HLV-H lathes we have at work before moving to CNC. All I can say is I adore them, they are tremendous machines. But you obviously know that.
    A good friend of mine purchased a 1948 Monarch 10EE earlier this year for his personal workshop. People often compare them with the HLV-H. His needs some TLC and I haven't personally run it, but it appears as though it could go toe to toe with the Hardinge.
    Honestly there is no comparison, and this is coming from a Hardinge cheerleader. The 10EE is a superior machine, even in its original configuration (Trav a dial and vacuum lines).
    I worked closely with a NASA machine shop and had an oportunity to run a 10EE fresh off our Hardinge (which is an early 90's model) and to my shear disbelief it was a better machine.
    One thing Hardinge does better than anyone is single pointing. I can run a set of 14Mx1.5 4" threaded shafts in around a minute a piece. (Ive been called on this, trust me its the machine not me!)
    • surebimmer
      • Jan 2004
      • 978
      #32
      Awesome work!
      What do you use for a throttle cable? Can you custom make a throttle cable?
      • shocwav3
        • Apr 2014
        • 69
        #33
        Originally posted by surebimmer
        Awesome work!
        Ive got a cheap universal one from Summit, I already dont like how it feels so Im going to pull a long one from an e38 or something and shorten it if need be.
        • e30austin
          • 15382
          #34
          This is amazing. Sub'd.
          '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
          • Liquidity
            • May 2014
            • 395
            #35
            Originally posted by shocwav3
            Talk about some hours! They would look awesome though.
            Lots of ball endmill work but it would really show off your design and programming skills. The good money is made in real 3D modeling and programming, something you should look into.
            How did you make the throttle plate?
            Couple ways you could do it. Clamp first side down, mill second side. Clamp second side down, remove first side clamp, mill first side. Or - drill holes first, clamp plate down through holes, preferably using large "washer" so the plate won't chatter, and mill entire OD in one shot. You'll need to make a fixture for either method.
            • Balleristic31
              • Aug 2009
              • 4198
              #36
              I would also be interested in the shifter setup! Amazing work man just pure art!
              -NICK
              • shocwav3
                • Apr 2014
                • 69
                #37
                I do a full 3d contour on all of my plenum bases and then blend it in by hand. The trumpets would deff be more eye candy than function. I know a lot of guys like to incorporate them into plenum designs, but I have do it both ways with heads up dyno testing and found the advantage to be negligible if any.
                Here is one I do with more of a modular design approach incorporating more 3d contouring.
                I fixture everything, while trying to universalize as many bolt patterns as possible. That way I an re purpose fixtures, they are time consuming to make but can pay off really quick in bigger runs.
                • shocwav3
                  • Apr 2014
                  • 69
                  #38
                  Thanks!
                  I wouldnt mind re-creating it.
                  • shocwav3
                    • Apr 2014
                    • 69
                    #39
                    Fuel Rail
                    Exhuast Work
                    • justin_l_
                      • Jun 2007
                      • 1079
                      #40
                      This thread delivers! Good work!
                      • MT325is
                        • May 2012
                        • 1103
                        #41
                        daumn!
                        1989 BMW 325is (SOLD)
                        1992 BMW 325IC (SOLD)
                        1991 BMW 318IS (STOLEN!)
                        2017 BMW M2 (WEEKEND WARRIOR)
                        1989 BMW 325IC (PROJECT(
                        2002 FORD ESCAPE (DAILY)
                        • ak-
                          • 12422
                          #42
                          I'm enjoying everything you're posting
                          1991 325iS turbo
                          • shocwav3
                            • Apr 2014
                            • 69
                            #43
                            Thanks alot guys.
                            • shocwav3
                              • Apr 2014
                              • 69
                              #44
                              Lets modify some 16" style 29's from an e39 to make them work for the E30
                              • shocwav3
                                • Apr 2014
                                • 69
                                #45
                                Finishing up the exhaust
                                [IMG][/IMG]
