Vanos not getting power
  • MrGreen
    • Feb 2012
    • 130
    I just completed a m52 OBD2 swap and am having problems. The car was feeling really sluggish between 2500rpms and 4000rpms. I called a shop and they said check to see if the vanos is getting 12v. I checked between that rev range and it is getting 0v. I checked my wiring harness connections at the cam/crank harness and they all seem connected correctly. Is there a fuse for the vanos somewhere that may have blown? What am I missing?
  • emmanuel.dlc
    • Jun 2011
    • 144
    the plug at the beginning of the rail, does it have any cable connected there? does your harness have a Y shapped 2 plug harness close to the vanos selenoid?
    confirm all your connections
    • MrGreen
      • Feb 2012
      • 130
      Yes. That harness connects the cam sensor, the vanos, the fuel rail and the crank sensor. All 4 are connected. Is it possible I hooked up something else wrong?
      • DesertBMW
        • Aug 2011
        • 1043
        yeah, you hooked up vanos to fuel rail harness instead of the Y harness.
        • MrGreen
          • Feb 2012
          • 130
          No, I connected the Vanos to the y harness and the other part of the y to the fuel rail. To verify there is no power to the vanos, I unpluged the vanos and put a multimeter on the female section on the y harness that connects to the vanos. There was no voltage at any rpm. I think it is supposed to activate (12v) between 2500-5000. The other two plugs on the y are connected to the cam sensor and crank sensor.
          • 328ijunkie
            • May 2007
            • 3961
            Have any codes? Vanos/Cam sensor codes will shut down vanos and it wont ever sent voltage to solenoid....
            Check Us out on Facebook
            Full Product Line Tuning
            • MrGreen
              • Feb 2012
              • 130
              I started the engine with a full tank of 87 octaine. I had a check engine light after the first 15 minutes. Drove it about 12 miles or so and I got these codes at first:
              [IMG][/IMG]
              [IMG][/IMG]
              Then siphoned it and filled it up with 91 and cleared the codes. Only driven it two miles. No codes yet, but the vanos is still not getting power.
              Last edited by MrGreen; 09-18-2014, 07:35 AM. Reason: pics were not showing before
              • 328ijunkie
                • May 2007
                • 3961
                I'm betting the vanos code is still there just hasn't posted to obd2 pids yet.
                • MrGreen
                  • Feb 2012
                  • 130
                  Is there a fuse for the vanos that I should check? If so, is it on the harness (where)?
                  • DesertBMW
                    • Aug 2011
                    • 1043
                    Look up wiring diagram and check for continuity directly from the ECU plug to Vanos plug,
                    • cormier
                      • 380
                      Dme/tune from that motor or from another?
                      • MrGreen
                        • Feb 2012
                        • 130
                        Bought the m52 as an OBD1 package off the forum. Converted everything back to OBD2 (because I want to make sure I can pass the CA bar). Ordered the ECU off EBay and had Markert tune it. So no it is not original to match the engine. But the tune should have solved that correct?
                        • MrGreen
                          • Feb 2012
                          • 130
                          Looking for the wiring diagram... I'm assuming that you are suggesting I check voltage (between 2500-5000rpms) coming from wiring harness plug (that the y harness plugs into)?
                          • atldohc
                            • Nov 2008
                            • 359
                            MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                            download this. check page 564(assuming you have a 96-97 m52). green/blue and red/white wire to vanos solenoid. looks like the dme grounds it with the green/blue wire. trace the red/white wire back to the common connection point. it looks like a lot of components share that same power source(look at center of diagram). if your injectors have power so should the vanos solenoid. if it doesnt i would suspect a break in the wire somewhere before it reaches it
                            • MrGreen
                              • Feb 2012
                              • 130
                              Wow thanks for all the help guys. Looking into all of it.
