TPS and Wack MPG gage
  • DTFE30
    • Feb 2011
    • 471
    Looking for some input here, I'm going crazy trying to figure this out.
    Ive recently developed an issue with my early model 325e with s50. when I start the car, the mpg gage will read 0 like it should when the car is stopped. After a few seconds it will start going from 0 to 40 and back then eventually stay at 40mpg thinking the car is moving. It works fine once the car is moving. Variables:
    - speedometer works, so good speed input from diff.
    - idle does not increase while coasting. Symptom of speed to dme not connected.
    - randomly throws throttle position sensor code. Will clear after cycle of key.
    - tps resistance is in spec and all wiring is correct to tach, fuel economy, and vehicle speed (tapped from red/brn on obc).
    Any help would be greatly appreciated!
    Sent from my SAMSUNG-SGH-I317 using Tapatalk
  • mpowerful
    • Jul 2013
    • 1273
    Si batteries?
    • DTFE30
      • Feb 2011
      • 471
      Originally posted by mpowerful
      Si batteries?
      They have been dead since I got the car.
      • DTFE30
        • Feb 2011
        • 471
        What should I expect to see voltage wise from the VSS signal from the cluster?
        • M3PO
          • May 2012
          • 537
          I think you may be over thinking this. It may just be the gauge. I have had to mix and match from multiple clusters to get all of my gauges to work.
          The MPG gauge I have in there now has behaved similarly once. But has been behaving since. Not sure what caused or fixed it though.
          • DTFE30
            • Feb 2011
            • 471
            I have tried two tachs now. Same result. I am only getting 11.3vdc from the vss from both the obc point and the green plig on the back for cruise control.
            • DTFE30
              • Feb 2011
              • 471
              So I tried it again when I got home. In closed loop, the mpg rests at 0 with a smooth idle. When its warm the mpg gage will still fluctuate and idle seems to drop then catch itself abt once every 45sec. I also noticed that when the gage is stuck at 40mpg and I rev it, the needle will go back to zero then back to 40. What sensor could cause this in open loop that isnt already being used in closed? A new OEM TPS worked for abt a month. Then it threw the code but had all good test results per Bentley. I put on a third known working TPS and I still get random TPS codes. Anyone have any ideas? starting to run out of options here. Case of BEERto whoever can help me solve this!!
