Fuel venting issues
  • BingM3
    • 863
    Fuel venting issues
    Hey guys have s50 in my e30m3, seems like my fuel is not venting as it used to.
    I hear a noticeable pressure release when I remove my gas cap (just got a new one).
    I also see the outer filler neck with some fuel.
    Never had this problem before. I've heard of the car having a fuel relief valve but have no clue where it is located or if someone can show me a picture where to find it. Would it be an e36 m3 valve or from an s14?
    Car has no more charcoal canister. Could it also be a purged return line?
    Fuel regulator pressure was checked and ok.
    Thanks for your inputs!
  • DesertBMW
    • Aug 2011
    • 1037
    So you plugged the charcoal canister line then?
    • tytypetersen
      • Mar 2012
      • 347
      Where does the tank breather fuel line go? I have my vent hose just hanging out venting into the atmosphere and it works fine.
      • BingM3
        • 863
        When these swaps are done, the canister is eliminated and supposed to be venting elsewhere
        • justin_l_
          • Jun 2007
          • 1079
          The canister doesn't have to be eliminated. People choose to eliminate it.
