318is M52 swap using g240
  • ecastpro
    • May 2014
    • 4
    Hello everyone, I have been searching for a little while but finding no luck. I wanna know if I can drop in the m52 and reuse the g240 FW, Clutch and PP. I am finding a lot of ppl using m20 flywheel. Can I swap the flywheel or do need a different one? The m52 still has the m52 starter and m52 flywheel. What should I do?
  • Poorboyz
    • May 2012
    • 2117
    If using G240/260 then use the M20 clutch and flywheel.
    Sent from my 831C using Tapatalk
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • R1dd1ck913
      • Jul 2014
      • 382
      Ok look here this is what I did. And I know a few others that have done it too. Go by a new pilot bearing for your car. Reuse your Clutch and all associated parts including your starter. You will need a shorter shifter and shorter drive shaft.
      Current
      99 328i (Sold)
      91 318is M50B25TU
      89 325ix (Parted out)
      87 325is (Parted out)
      95 525i (Parted Motor for 91 318is)
      • ecastpro
        • May 2014
        • 4
        I thank you guys. I am ordering the parts mentioned. Hopefully everything works out great.
        • ecastpro
          • May 2014
          • 4
          BTW I believe you mean the m52 pilot bearing.
          • 328ijunkie
            • May 2007
            • 3961
            Pilot bearing matches Trans not motor
            Check Us out on Facebook
            Full Product Line Tuning
            • LegitimateIII
              • Aug 2014
              • 18
              I guess on a budget? Find a donor and get it all in there. M3 driveshaft is the tits no?
              • Nick_S
                • Apr 2011
                • 3658
                For whatever it's worth. I reused my G240 flywheel and a brand new M42 clutch with my m%0 swap and it's holding perfectly fine. Lighter is ideal but on a budget it will work fine.
                91 318is M50 swapped
                05 Honda Pilot
                24V swap thread
                • ecastpro
                  • May 2014
                  • 4
                  If the clutch doesn't hold up to the added power then Ill swap in as needed. I figured I can document it and make a contribution to the community.
                  • THEhomelessONE
                    • Oct 2013
                    • 303
                    I didn't change a thing, remove g250, insert g240 lol. Just need to measure the pilot bearing, certain years differ. I think I used an auto e36 318i driveshaft, not 100%, but it fit perfect, no splines showing.
                    RIP 02/25/15
                    http://www.r3vlimited.com/board/show...16#post4356816
                    • rudenate
                      • Jul 2012
                      • 16
                      Pretty sure the M42 and M50/52 pilot bearing is the same part number. Starter is also the same for M42/M50/M52/S50/S52. The 240 bolts on just fine to the M50/52 with clutch/fw/etc.
