Car is a 325i 1989.
First problem:
The buzzer start to buzz for no apparent reason when the car is parked and all thing turned off... and all doors closed and lights off. It starts 30 to 60 minutes after the car is turned off and never stop until I open and close the door. then it start again like 30-60 minutes after...
What can it be?
Second problem:
I happened twice that the engine turned off for no reason. Happened when the engine was cold (like less than a miles from home). Both times will the clutch was press and I was near a full stop. The engine just stop and all the lights that are normally lighten up before starting are lighting up... When it happened, I just restart and everything is fine...
Could it be one of the relays? Like DME relay?
Thanks!
First problem:
What can it be?
Second problem:
Thanks!
