Swapped Input flange on my 3.23 LSD to 6 bolt
  • Mistawall
    • Dec 2013
    • 319
    OK so i went and bought a driveshaft for my swap not realizing it was 6 bolt. tryed looking for a 4 bolt but it was stating to become a pain in the ass. so i just bought a 6 bolt flange. so we installed that and tightend it with the imapct gun and it got real hard to move so we loosened it and tightened it to 70# with a tourque wrench now it moves freely. thoughts? i dotn wanna fuck my shit up if i run it.
    my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
  • dirtbag30
    • Apr 2013
    • 678
    probably already caused damage to the crush washer in the pinion bearing.
    the proper way to swap flanges would be to make a mark on the old nut and pinion shaft before removing the nut. and count the rotations as you would on a tie rod just to know how far the nut was on the shaft.
    and to install you tighten the nut until it starts to get tight. it should be the same amount of revolutions it took to take it off and it should also line up with the marks you made in the beginning.
    or at least thats how i did it when i swapped to a six bolt flange and haven't had any problems yet.
    edit
    see picture
    IMG_0364 by alec.ruonavaara, on Flickr
    i have no idea what i am doing with my life
    • justin_l_
      • Jun 2007
      • 1079
      There is a crush washer on the pinion it is probably screwed now
      • pantelones
        • May 2011
        • 533
        There is a crush sleeve that is meant to be replaced when rebuilding the diff, and it can be salvaged if you are just replacing the seal, or input flange. You actually need to use a dial indicator to re-seat the pinion seal to ensure minimal leakage. In addition to what I just stated, the steps below is what you should have done...
        Now you need to replace the crush washer, and rebuild the pinon bearing assembly.
        A man chooses, a slave obeys... Would you kindly?
        • Mistawall
          • Dec 2013
          • 319
          Fack. well the diff isnt in the car. wonder how much that will cost cuz i certainly dont have the know how for that.
          • Mistawall
            • Dec 2013
            • 319
            i just called up a transmission/driveline guy gonna see what he will charge me...
            • 328ijunkie
              • May 2007
              • 3961
              Impact gun, fail.
              Check Us out on Facebook
              Full Product Line Tuning
              • Mistawall
                • Dec 2013
                • 319
                sweet so he told me to order all the seals and crap might as well replace everything since he gotta take it apart. said liek $150 in labor
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  That's crazy cheap, and almost concerning. Most people get quoted ~1k for a diff rebuild it seems.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    wicked cheap
                    • Mistawall
                      • Dec 2013
                      • 319
                      using this thread as a parts source
                      • Mistawall
                        • Dec 2013
                        • 319
                        im just replace seals and crush sleeve
                        • justin_l_
                          • Jun 2007
                          • 1079
                          Yea, that's reasonable. I paid 450 for parts and labor to have the rear end in my durango rebuilt. BMW speciality shops just like to charge a lot.
