M50 getrag 240 won't start
  • zer0_paint
    • Jul 2014
    • 864
    Ok just finished the m50 swap with the getrag 240 transmission using the euro 323i throw out bearing m20 clutch m20 flywheel and m20 starter and we go to crank the car and it's just a loud clunk, motor won't even rotate manually... Any help please.. Thanks
  • 328ijunkie
    • May 2007
    • 3961
    clutch in backwards? car roll in neutral?
    Check Us out on Facebook
    Full Product Line Tuning
    • zer0_paint
      • Jul 2014
      • 864
      car is on a rack, with no driveshaft.. , just finished the wiring and tryna crank the motor to see if it will start..
      • GunMetalGrey
        • Dec 2010
        • 1499
        Was the engine known running?
        Does anything change if you push in the clutch and try to start?
        • zer0_paint
          • Jul 2014
          • 864
          motor was pulled from a running e34, i started the car up and heard it run for about 20 mins, sounded fine..
          • justin_l_
            • Jun 2007
            • 1079
            Machine the back of the flywheel? It bet it's hitting.
            • mpowerful
              • Jul 2013
              • 1273
              Have you tried turning motor over by hand?
              • Nick_S
                • Apr 2011
                • 3658
                I second the flywheel. If it wasn't machined it will have clearance issues.
                91 318is M50 swapped
                05 Honda Pilot
                24V swap thread
                • mpowerful
                  • Jul 2013
                  • 1273
                  I missed the part that he had already tried that. Doh. : ( Looks like he will be taking it apart.
                  • GunMetalGrey
                    • Dec 2010
                    • 1499
                    This is a very good possibility depending on what you used
                    • justin_l_
                      • Jun 2007
                      • 1079
                      Judging off the post asking how much to remove from the back of an m20 flywheel he knows what he did now.
