What alternator should i run?
  • QUKBMER
    • 8178
    I am doing a s50 swap in my late model e30 and i need to order a reman BOSCH alternator and they have 80amp and 140 amp which should i run? As the motor i have doesn't have one on it.
  • Poeman446
    • Jun 2013
    • 227
    Can't you just look for the OEM alternator for a 95 M3, and use whatever it specifies?
    • AndrewBird
      The Mad Scientist
      • 11892
      If it fits, I'd go with the higher amperage one.
      I know on e34s automatic cars got a higher amp alternator than manual cars. Could be the same for m3/e36.
      • justin_l_
        • Jun 2007
        • 1079
        If you plan on supercharging you usually have to grind the 140 amp alternator.
        • QUKBMER
          • 8178
          Well they offer both alternators on the 95 m3 80amp and 140amp. I think i will go with the 140 amp since the late model e30 325i uses a 95 amp on a auto or manual car. Wouldn't make sense going backwards in amp's.
