m50nv harness with a m52
  • e30m20TurbO7
    • 1203
    will a non vans harness work on a m52 swap?
  • justin_l_
    • Jun 2007
    • 1079
    No
    • Nick_S
      • Apr 2011
      • 3658
      Non vanos doesn't have knock sensors, so no.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • Kevinl
        • Oct 2012
        • 897
        or vanos :D
        1989 BMW 325is Lachsilber metallic 5 speed
        2007 BMW 335i KARMESINROT 6 Speed manual
        2011 BMW X5 35I
        • Nick_S
          • Apr 2011
          • 3658
          Originally posted by Kevinl
          or vanos :D
          Yea...that too
          05 Honda Pilot
          24V swap thread
          • DesertBMW
            • Aug 2011
            • 1043
            Yes. You can run M52B28 engine with 1992 non vanos engine management.
            Non vanos doesn't have knock sensors, so no. or vanos
            He wont be able to use vanos solenoid not knock sensors on 1992 bosch non vanos engine management anyway. LOL
            • Nick_S
              • Apr 2011
              • 3658
              I'm confused by what you're saying. He has a NV harness, which does not have the wiring for vanos and knock sensors. How he could run this on an M52 with knock sensors and vanos (double vanos?).
              05 Honda Pilot
              24V swap thread
              • justin_l_
                • Jun 2007
                • 1079
                If you ran non vanos engine management it would not need the knock sensors or vanos control, so you "could" run the harness. But I was keeping it simple as it is not plug and play for an M52 swap. I'm not sure if you would have to lock the vanos to run the non vanos setup or not but you would have to look into that as well.
