M50 M52 hybrid help
  • CarsSuck
    • Oct 2005
    • 968
    M50 M52 hybrid help
    I already have an m50 Vanos motor. Im gonna be pullng an M52 from a 328 convertible. Which parts should i use from which motor? Also Im probably going to run s52 cams, what software should i get?
    --Will
  • BimmerToad
    • Sep 2004
    • 1537
    Use the cylinder head and bottom end from the 2.8L. You'll get a better and larger bottom end, and updated cylinder head valvetrain
    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
    • CarsSuck
      • Oct 2005
      • 968
      I figured that was the case. Can i swap the valve train into the m50 head to avoid having to tap the head for the coolant sensor?
      --Will
