Cost for 24v swap aside from the motor
  • mcdougal
    • Nov 2014
    • 251
    I just picked up an 86 325i with a blown motor and plan to do a 24v swap of some sort. I've researched costs as much as I can and have seen estimates as low as $900 for a diy m50 to as much as $10k for an s50 installed by a shop.
    My question is, aside from the motor (undecided on m50 for a few hundred bucks or an s50 for a couple thousand) and assuming I will use the stock e20 transmission, what should I expect to spend on the remaining parts? This is just for the swap-related parts; not the wiring which I might do myself or pay a member to make me a wiring harness, or engine tune-up parts (head gasket, water pump, etc which will be another $500 or so I think).
    It seems like I should be able to get everything for under a grand if I buy used wherever possible. Is that crazy?
  • justin_l_
    • Jun 2007
    • 1079
    Why you plan on doing a head gasket? Yes 1k is possible but not likely when you start doing maintenance.
    • mcdougal
      • Nov 2014
      • 251
      I only plan on doing a head gasket if it needs it. Just planning for the worst I suppose.
      Is $1,500 to $2,000 about right for an s50 motor?
      • Nick_S
        • Apr 2011
        • 3658
        For a basic M50 swap with some maintenance and parts needed and doing it yourself, plan on $2k. I could be more, it could be less. I managed to do mine for around $1500 with quite a few new parts and lots of gaskets.
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
        • dude8383
          • Jan 2005
          • 10387
          Whatever your budget it is... multiply it by two. Happens all the time. If you think you can do all of the maintenance for less than $500... plan for $1000.
          There's ton's of while you're in there stuff that really should be done before the engine goes into the car.
          • mcdougal
            • Nov 2014
            • 251
            Thanks for the responses.
            • mcdougal
              • Nov 2014
              • 251
              Would you mind sharing what you believe are while you're in there must-haves?
              • justin_l_
                • Jun 2007
                • 1079
                This will give you an idea.
                • dude8383
                  • Jan 2005
                  • 10387
                  Spark Plugs
                  A/C Belt
                  Main belt
                  Thermostat
                  Thermostat Housing
                  Coolant temp sensors
                  Water Pump
                  Upper Coolant Hose
                  Lower Coolant Hose
                  Oil filter
                  Guibo
                  Valve cover gasket set
                  Motor Mounts
                  Intake Boot
                  E34 Oil Pump Gasket
                  E34 Oil Pan Gasket
                  E34 Oilpan, pick up, pump, dipstick
                  Shifter rod joint
                  Delrin Shift Carrier Bushing
                  E34 throttle cable
                  Spider Hose
                  Idler Pulley
                  Clutch & Flywheel
                  rear main seal
                  Pilot Bearing
                  Vacuum Line ICV Connector
                  Vacuum line to ICV
                  Intake Manifold vacuum
                  Intake Manifold vacuum thinner line
                  O2 Sensor
                  This roughly comes out to $1400 based on a previous build.
                  If you're getting a ZF Gearbox:
                  5th gear lean fix for ZF gearbox
                  5th gear spring
                  Shifter Detent Pin (5th Gear)
                  The list in that link is far more comprehensive though.
                  • Nick_S
                    • Apr 2011
                    • 3658
                    I'll give a quick list some of what I replaced. I don't have a nice spreadsheet to share unfortunately.
                    These were all the gaskets I did:
                    -oil pan
                    -oil pick up
                    -valve cover
                    -intake manifold (6)
                    -throttle body
                    -rear main (need to do again)
                    -oil filter housing
                    -dipstick o-ring
                    -injector 0-rings
                    -trans input shaft
                    and a few other various ones
                    And some of the hardware I did. All new
                    -alternator
                    -waterpump
                    -clutch
                    -belt
                    -mounts
                    -intake boot
                    -various vac hoses
                    -E34 pan
                    -G240 euro linkage
                    -CSB
                    -radiator hoses
                    Add to that all your fluids, the cost of the engine, wiring, DME and other various things and I was at around $1500 and I would consider mine pretty basic compared to others, but this got me a well running, decently clean swap.
                    05 Honda Pilot
                    24V swap thread
                    • mcdougal
                      • Nov 2014
                      • 251
                      Thanks dude and nick!
                      • mcdougal
                        • Nov 2014
                        • 251
                        Found an M50 at a local yard for $400 that I'm going to pick up. I'd prefer an S50 but for $400 it seems like a good start.
                        Question: I know the M50 manifold is a common upgrade for the S motors. If I'm buying an M motor there isn't any reason to upgrade the manifold is there? Thinking I'll throw some cams in there at some point to spice it up a bit.
                        • dude8383
                          • Jan 2005
                          • 10387
                          The M50 intake manifold is used on the M52/S52 motors because they had a narrower manifold design.
                          • mcdougal
                            • Nov 2014
                            • 251
                            Ok so if I get an m50 then the intake mani would be w worthwhile upgrade right?
                            • justin_l_
                              • Jun 2007
                              • 1079
                              It should have an m50 manifold on it. That is what it comes with from factory. Not an upgrade when installing a factory part.
